WiFi and ADB
I am trying to connect a pen WiFI with chip RT chipset 5370 to NanoPi Fire3. I am planning to use a USB hub to connect the pen WiFi and a mouse, is it possible? I tried, the mouse worked fine but the pen WiFi didn't work, I don't understand if it's because NanoPi is not compatible with this WiFi chip or if it's something else. I tried to connect to Android with ADB but without success, I run the command "adb devices" but there's no results. Any suggestions are welcome.
Best regards,
Manuel Sobral
EDITED: Made a mistake typing the chipset
Meanwhile I compiled the kernel with the ralink modules as indicated in this tutorial,
https://www.element14.com/community/com ... u-platform
It still doesn't work but I only compiled the kernel. Do I have to upgrade the firmware too as indicated in the tutorial?
Meanwhile I added a firmware file but still doesn't work.
http://wiki.friendlyarm.com/wiki/index. ... Fire3#WiFi
it's mentioned that this board will work with
RTL8188CUS/8188EU 802.11n WLAN Adapter
RT2070 Wireless Adapter
RT2870/RT3070 Wireless Adapter
RTL8192CU Wireless Adapter
mi WiFi mt7601
but I start to doubt it. Or maybe not with Android. Can someone confirm if there's a pen USB WiFi that works with Android?
Hello Manuel,
Are you using AndroidWifiADB plugin? Here's the ADB over Wi-Fi discussion - https://stackoverflow.com/questions/423 ... -over-wifi
I tried to connect to Android with ADB over TCP as well.
professional essay service help
