PWM on Android
I'm trying to dimming a led with PWM and the libfriendlyarm-hardware.so library but I'm only able to set the frequency and not the duty cycle.
Do you know how can I manage the brightness of my led ?
Re,
In absence of any answer..,
Can you provide the source code of your library please ?
Maybe I can implement this by myself.
Hi Sidi,
did you make any progress? Currently I am facing the same challenge: controlling a TFT backlight with PWM.
Final result should be integrating the PWM signal into the Android system brightness slider.
@FATechsupport
Any suggestions?
