Installing New Package at Debian OS.
I install the new package in Debian OS then reboot to boards. boot up to OS not see the packaged have installed the last.
What happened ?
--Regards,
HuyLe
Try to install it again. apt-get will soon tell you if it is on your device.
If it doesn't appear try apt-get install dctrl-tools and then I'll give you some commands to run
try installing the program again maybe it was saved in a different directory and the command wasn't linked or something
also check that your card isn't failing or corrupting the data.
BACILY wrote:
If it doesn't appear try apt-get install dctrl-tools and DigitalOcean SiteGround iPage then I'll give you some commands to run
This is one way how SD card shows that its going to die. https://forum.armbian.com/forum/31-sd-c ... su-issues/
