Flash Image to NanoPC-T3's eMMC ... problem
Successful SD card operation so tried to put the images onto eMMC. So, downloaded debian-jessie-images.tgz untar that to SD card and when booting up using the SDcard I get:
hub 1-1:1.0: hub_port status failed (err = -110)
then stops for several minutes then displays:
Ubuntu-core login: (???)
fa
fa
So I didn't see any "Debian is fused successfully".
Do you need the LCD or HDMI connected to proceed, ie using the PS-ONECOM to monitor the boot process is not correct?
After several attempts I see it stops at different places during the boot process, Started Journal Service is a common stopping point. I have a 2A power supply.
davef
I have been able to boot using the eMMC in spite of the long wait period at
eth0: device MAC address 02:81:7f:36:69:9b
as mentioned above and the message that I seemed to have loaded Ubuntu-core. No sign of
Debian is fused successfully.
All done.
However, I will proceed to customise the rootfs.
Got rid of the long wait by changing /etc/network/interfaces eth0 entry to:
iface eth0 inet static
reboot in 25 seconds.
fa
fa
davef
Now you can get the eflasher utility s5p6818-eflasher-sd8g-xxx-full.img.7z to flash image to eMMC directly. About detailed description you can read this page:http://wiki.friendlyarm.com/wiki/index.php/NanoPC-T3#Flash_image_to_eMMC_with_eflasher
thank you!
