Debian - WiFi and CPU-Temperature
i'm running two NanoPiM3 with Debian. Is there a way to disable the wifi-module in the config-file on the boot-partition? How can i get the cpu-temperature on the shell?
Best regards.
view cpu-temperature:
# cat /sys/class/hwmon/hwmon0/device/temp_label
if you want to disable wifi, you just need to edit /etc/network/interfaces and add a non-auto entry for your weak network adapter like so (where wlan0 is your weak adapter):
Code:
auto lo
iface lo inet loopback
iface wlan0 inet manual
Thank you!
