Flash eMMC?
I have two issues with flashing an image to the eMMC.
1) Following http://wiki.friendlyarm.com/wiki/index. ... ux_Desktop i'm able to boot from the emmc. But this works only if there's an additional SD card present. When removing the SD card, i get this error message:
Card did not respond to voltage select!
** Bad device mmc 1 **
Error: could not access storage.
Is there any possibility to not need an SD card when booting?
2) By using ./fusing.sh, an image is downloaded and used (file rootfs.img). Is there any documentation available if i want to use my own image (eg copied from a working sd card)?
Thanks in advance
Thomas
I was able to answer question #2 myself. Basically you just need to dd the second partition of a working sd card to /dev/mmcblk1p2 (after running fusing.sh).
But i still need an sd card in the slot when booting from the emmc. Any hints on this?
In total there are 49 users online :: 0 registered, 0 hidden and 49 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 49 guests
