HD702 LCD on NanoPC-T3 Plus Resolution Flip
Does anyone know if you can switch the resolution on an HD702 LCD display from the 800x1280 to 1280x800, it is attached to a NanoPC-T3 Plus so I can use it like a laptop instead of a tablet?
Sent an email to tech support asking this same question, and was directed to the wiki and to the Lubuntu OS page which had the directions to rotate the screen clockwise 90 degrees. No other reply is needed.
Which OS as I rebuilt the Android source to swap the display to landscape on boot up. Works with the 4.3 and 7.0 displays that I have.
If I can find somewhere to host the source I'll do so but at 10GB I've been unable to find anything suitable so far.
Do you find way to config Lubuntu and android to resolution 1280x800?
can you share your image with with this solution?
