Install not working
I used Mini 210S a long time with WinCE 6 installed on the NAND flash. with the newly purchased board, there is change in the memory to Micron. I am no longer able to flash the board using SD card or Minitools. After one unsuccesfull flash with MiniTools I cannot get the board into flashing state (3 buttons on the side) and flash using MiniTools.
Using microSD I can get it to boot a system directly from flash but when I use the Install command in FriendlyArm.ini, nothing happens. Not even the led flashing.
Do I need to change the .ini file or the bootstrap? I use superboot for 210S and on the previous version the SD card it works just fine.
Thank you very much
Regards,
Milan
Same issue
