GPIO wrong access address
I'm trying to use the HardwareController and libfriendlyarm-hardware.so to get access to GPIO.
But it comes with this error: "D/FriendlyARM-HW-Lib: Unable to open file /sys/devices/virtual/gpio/gpio62/direction"
I guess the problem is with the library file which is trying to look into wrong location.
Any solution to this?
We updated the latest 2017-03-08 (4418,6818) img has support android 4 android 5 hardware access library, you can refer to
http://wiki.friendlyarm.com/wiki/index. ... are_Access
After installing android 4.4 the problem is solved, apparently the error occurs for Android 5.1
Thanks Chensy. The problem is solved. The GPIOexport funtion is also working properly. SPI is working fine as well.
PLEASE ADD KERNEL LI-ION BATTAERY CHARGE OPTION
