Battery pins on NanoPi2
Posted: Thu Jan 14, 2016 5:05 am
by meisam
Hi there.
I have bought a nanopi2 hardware. there are 2 pads on the board between RAM chip and WiFi module, seems to be for battery wire soldering. Is it correct?
and if correct, which type of battery could be connected? rechargeable battery or non-rechargeable CR20xx type?
Re: Battery pins on NanoPi2
Posted: Thu Jan 14, 2016 10:29 am
by FATechsupport
Hi I am not quite sure which points you referred to . I would guess you referred to the two points I marked in the attached screenshot. If my guess is correct yes they are for RTC. It is for non-rechargeable 3~6V battery
Posted: Thu Jan 14, 2016 4:19 pm
by meisam
hi
you guessed right & it is excellent that this board has RTC backup battery holder.
Thanks for your guide.
Posted: Fri Apr 29, 2016 11:53 pm
by @lex
Can you please confirm the correct polarity:
[_] -> +
O -> -
Is this correct?
Posted: Wed May 04, 2016 2:00 pm
by @lex
ahh, ok, i just found it on the wiki: http://wiki.friendlyarm.com/wiki/index. ... 602-if.png
